Kermy
- Jun 4, 2002
Just ordered a pair from Sennheiser. Going to see how they compare to the Bang and Olufson H8.
Did you get the over ear bluetooth one? If so definitely please let me know your opinions between the h8 and momentum v2 these two headphones im having trouble researching and chosing which to buy
Yea I ordered the over ears. I put some quick impressions in the H8 thread earlier, but as of right now, I'm not too impressed with the H8's sound quality. I love some of the features though when compared to the Momentums like replacable battery, can turn ANC on and off and swipe controls on the side.
Crap i didnt even think about going to an h8 thread. Sweet! I'll check out your impressions. What dissapoints you about the sound quality of the h8? Also are you burning them in as of now? How do the swipe controls work is it like some kind of touchscreen interface sorta where you use a finger to swipe left right up and down?
interesting looking forward to a review if you plan on doing one amd a vs between the two also!Yep the touch control is like having a touch screen on the side of the headphones. It's pretty awesome. The biggest let down for me is when ANC is on. The sound sounds hollow and limp (lacking bass). With ANC off, it's pretty good, but seems to lack the neutrality and resolution of the H6.One thing I haven't tried is using them with the cable in.
I just used a iPhone 6 as the source.
I will be able to have a long session with them tomorrow. I'll report back if I experience anything.
Same here
I am getting these in tomorrow. The over-ear ones (non-wireless).
The original Momentums were too small for my ears, my ears would literally start hurting after 30 minutes of use. So I am hoping these will be better.
I will post about this and other findings tomorrow.
