jkjk123
Hey guys,
I have the Sennheiser Momentum 2.0 and enjoy its sound (though I do feel that deep bass could be improved).
Like many people, I had issue with the size of its earpads, and did a good amount of research on replacement earpads with no good results. I tried the Brainwavz HM5 angled pads - they fit too loosely and definitely affected the sound.
I decided to try getting custom pads made from Vesper Audio. The process went pretty smooth - I provided them with pictures and measurements of the earpad retaining mechanism of the headphone, along with desired thickness/height/weight dimensions of the earpads. I decided to get all leather earpads with memory foam - as I was hoping that this would change the sound the least.
Default Momentum 2.0 dimensions:
Cavity width: 40 mm
Cavity height: 60 mm
Thinner side pack thickness (on outside): 17 mm
Thicker side pad thickness (on outside): 25 mm
I opted for:
Cavity width: 40 mm
Cavity height: 68 mm
Thinner side: 22 mm
Thicker side: 30 mm
I receive the pads about 3.5 weeks after payment had been made (they have to ship from Belarus).
The pads were nice and well made. Accurate enough to the specifications. I had difficulty putting them onto my M2s since the retaining ring portion was too thick to fit in the slot on the headphones (so forced it in slowly with a collar stay). It took a while, but eventually I got it all in.
The fit was very nice. Unlike the Brainwavz pads, which aren't made for these headphones, the pads fit nice and tight around the cups of the headphone. I feel that a good fit is important in order to get a proper seal. The pads were just deep enough for it to be significantly more comfortable than the stock pads.
The sound, however, still changed! I noticed that the bass actually improved and was quite nice. I don't think I ever got a proper seal on the stock pads since they didn't fully fit over my ears. I felt the bass with the new pads were improved and sounded more full with deep bass notes. Unfortunately, the frequency response of the headphones with the new pads definitely changed significantly. I noticed quite a bit more treble, with a rather large peak around 4-6 khz. I had to apply EQ pretty heavily, but even then it did not sound like the original pads.
Lesson is: I'm gonna stick with stock pads from now on for future headphones, as I feel it always changes the sound unless you know exactly what you are doing (in terms of exterior and interior - type of foam - materials).
Cavity width: 40 mm
I opted for:
Cavity width: 40 mm
Thinner side: 22 mm
Thicker side: 30 mm
