I've just received the Momentum 2 .....after returning Momentum 1 after only 6 days - the rubber slider (that white very small one) on the slide mechanism just came off in one side - shocked to see this ...anyone else experienced that?
I will write an email anyway to Senn CS about this
I've ordered the Momentum 2 before the rubber slider problem with the Momentum 1 so now I am a bit concerned ...will they have the same problem, should I return them and buy something else...!?
Momentum 2 PROS:
-in terms of sound they sound pretty much the same as far as I remember the Momentum 1
) the bass is slightly boosted , just a tad though and treble rolled off a bit, I would have preferred more presence , highs
- the comfort is 10 + ...I was very satisfied with the MOMENTUM 1 also in terms of comfort but the MOMENTUM 2 are fabulous , very very light , no pressure at all , perfect I would say
- they fold perfectly without even moving the cups sliders all the way up as the previous version needed to fit the case
Momentum 2 CONS:
- I ordered the Android version cable and with my HTC One the remote does not work as expected vol+ send me to the prevois track and vol - sends me to the next track, the center button - play/pause
it works though perfect with the Note 4 - all functions of the remote
strange because on the package and website its clearly stated "Samsung Galaxy, HTC, LG, Sony and others smartphones /tablets"
- I just hope the slide mechanism does last
- you receive now only one cable (not 2 , and no 1/4 jack) . the cable seems the same quality but the remote is plastic and the jack is part plastic part metal - but not that fabulous metal jack from the Momentum 1 - such a disappointment
- the case is smaller and very nice but nowhere near as sturdy as the first momentum had
I guess they cut the costs on cable and case and improved what the customers suggested
