Do the sennheiser IE80 have a more exciting sound compared the the HD600/650 etc?
I am thinking of swapping my HD650 for some IE80 because I find the HD650 boring and lacking in sub bass...
I have both and let me give a little insight to you.
IE80 does sound more exciting, because it sounds fullers compared to the hd650.
HD650 is probably boring because the middle-left and middle-right channels are sort of missing, or should i say
the audio on hd650 is clearly distinct between middle, left and right, leaving only instrumental details on place between middle and left/right.
I have never heard the hd650 to lack sub-bass, instead i tone the 100hz down when i had it with the default cable, i have since replaced it with twspc,
which brings out the mids more and tames the bass.
If you do change to a ie80, i will tell you the first thing you will miss is the clarity on the hd650, the ie80 in comparison does sound a little muddy.
The hd650 is clearly better than ie80 in almost all aspects but is more analytical thus less exciting.
If details/definition doesn't bothers u too much, changing to the ie80 is worth it.
But bring me to the point of what u do with your hd650, it's a home setup to me, u probably didn't drive them properly enough to make them exciting/warm enough.
