Sennheiser IE800 IEM's
Jul 31, 2019 at 2:47 AM Post #7,547 of 7,998
hey hi!
This Sennheiser ie800 is original? Thank you!
audifonos-sennheiser-ie800-como-nuevos-oferta-D_NQ_NP_849093-MLC29028258999_122018-F.webp
audifonos-sennheiser-ie800-como-nuevos-oferta-D_NQ_NP_859942-MLC29028293130_122018-F.webp
audifonos-sennheiser-ie800-como-nuevos-oferta-D_NQ_NP_618048-MLC29028297079_122018-F.webp
Jul 31, 2019 at 11:48 AM Post #7,548 of 7,998
Anyone have a simple trick to easily tell L from R earpiece? The L and R letters on each are nearly unreadable except in the brightest light, and the tactile bump on L is too small for me to feel?
Thread? Nail polish??
Jul 31, 2019 at 12:01 PM Post #7,550 of 7,998
I was thinking nail polish too, but I didn’t because I don’t want to risk the chemicals possibly damaging the cable, and, it’s not permanent (will chip off eventually.) Would like to know if someone has found a good way to do this.
Jul 31, 2019 at 4:59 PM Post #7,553 of 7,998
I used nailpolish on the cable but it soon came off. There is a slight tilt in the housing that you can feel even in the dark that aids in the insertion.
Jul 31, 2019 at 5:16 PM Post #7,554 of 7,998
I just know by the shape of the earpiece if it's for left or right when I have it. It's not that hard to remember I guess?
Jul 31, 2019 at 11:28 PM Post #7,556 of 7,998
Try to match the SN on the packaging barcode with the leather wallet.
Can you also post a closer image of the sennheiser logo on one of the cans? Also, a picture of the Y splitter and the L 3.5mm jack.
Yup last 5 digits of the serial should match what’s on the leather case. Very hard to spot physical differences. Although the tips on the fake ones are usually loose.
Jul 31, 2019 at 11:39 PM Post #7,557 of 7,998
Hard but not impossible :)
I have my second purchase of this IEM done by checking the SN and by the images (the first one died after its 6th anniversary). The fakes usually have a somewhat less neat moulding marks and a somewhat stiffer curve of the Senn logos.
Jul 31, 2019 at 11:41 PM Post #7,558 of 7,998
Here is mine for comparison attached.
I also noticed that the original has a darker green cable that fakes.
Jul 31, 2019 at 11:54 PM Post #7,559 of 7,998
https://imgur.com/9IExWvn
9IExWvn
The Sn match, i think they are original i talked with a owner and nothing is wrong with my ie800
Very nice speed/image/resolution
Aug 1, 2019 at 12:04 AM Post #7,560 of 7,998
9IExWvn
I would suspect that you got the real one. Congrats and enjoy. Very amazing iem housed in a small tiny body shell.
