62ohm
- Oct 13, 2013
A few thoughts. I love the HDVA600. I read somewhere that buying it for the HD800 is basically like buying the Beyerdynamic A1 for the T1.
No. Just, no. Don't let ill informed comments like those dissuade you from trying this amp.
I like gain setting 2 best for the HD600. I like gain 3 and higher for Audeze headphones and Mr. Speaker headphones.
That said, the HDVA600 is pretty expensive. Has anyone heard any other amp that sounds like the HDVA600 but costs less?
I also like the HDVA 600 for HD650 and K812, not so much for the SRH1540 though. I tried the SRH1540 driven by the Senn amp before, and the bass became utterly loose and bloated.. I honestly think even cheap DAPs will be better for the SRH1540.
And although I never get the chance to listen to both side-by-side, from memory the Graham Slee Solo SRGII sounds very close to the SE-out of the HDVA 600. Take this with a grain of salt though as I didn't listen to them side-by-side.
