Most people commenting on hd820 never actually heard one or heard one in suboptimal conditions and are just commenting based on what they think they should hear from the frequency range response. Does not sound congested at all IMO from first hand experience. I owned the hd800 and the hd820, I only own the hd820 now tho
The largest difference between in the two is that the hd820 has significantly more bass and is more isolated than the hd800s, while the hd800s has a significantly wider soundstage than the hd820. The rest is mostly minutia.
I would really look at how important bass response is to the music you listen to is, and if it's very important the hd820 is the obvious choice. If its not that important at all you might be better off with hd800s.
I enjoy the slam and response of my HD6XX, I don't see myself boosting it unless I want to feel dirty with some songs. Synthwave/Retrowave on my HD6XX sounds fine, just need to heighten the 3.5khz+ and beyond a bit.
I rarely use my Mobius as my earcups get pretty hot and potentially sweaty on LONG days when I am at my desk for like 17+ hours cause of work and the sound... I can't put my finger on it, it just sounds fuzzy.
I usually put that on "FLAT" mode but I don't believe it is flat.
I have tried EQing some 300hz - 2khz down and male vocals sound more, clear? I dropped these EQ down 3-4dbs and it seems to isolate the vocals more which results in having a clearer sound?
This is consistent in my IEM, both headphones. Does this mean I enjoy a V shaped sound or is it just the gear?
Whenever I use my IE80s, I have to really hit the mid down several db to have the "clarity" I want.
I normally do a LOT of research and trial and error with myself; however, I was made an offer where I can have the HD820s for the same price as a HD800s in CAD because my 800s have been on order for like over 2 months, still no ETA yet.
I personally think that the most important key notes for my sound preference would be:
- Clarity
- VISCERAL impact on kick drums, I prefer the Kick to destroy me rather than the deep "wub wubs" if that makes sense, forgive my ignorance on identifying the sound.
- Vocals
- Piano melody or Glockenspiel need to be very present. (Ex. Infected Mushroom's Franks near the end of the song, 7mins in? iirc, or Nier's City Ruins - Rays of Light's piano melody amongst the vocals)
- I would like a much larger soundstage compared to my HD6XX, I usually find myself using my speakers to fulfill that need.
I was under the impression the HD800s was going to be my best fit and if I needed bass, I'd just EQ them a bit.
At this point would I need both to satisfy my needs depending on each song?
I really appreciate everyone's response and assistance in my extremely rushed decision I have to make.
I have both and they different enough to justify getting both....if you can.
I mean at this point I might have to lol
