Svatopluk
- Sep 13, 2014
That would be a clear sonic downgrade from his Mojo, though.
I'm just an old guy with unbalanced hearing, give me a brake.
Hmmm, so there is no way to add bass quantity this HD 800S with lets say compared to LCD X ?
what a pitty.. is any solid state amp (balanced) can add PRAT to this lovely headphone ?
As I said, you can't bypass the Mojo's (and Hugo's and DAVE's) headphone output – it's the same signal path as the line output, since there's no dedicated headphone amp built in. Other DACs have a different topology, and you can bypass their headphone output (if available). So if you don't need higher power, it makes no sense to add an amp if you're looking for higher sound quality and accuracy (objectively spoken). You can't improve a signal by re-amplifying it.
I'm not sure if I follow you. What is the difference between Chord Hugo output stage and other DAC's like the Auralic Vega which make it a problem? If Auralic simply added a headphone port directly onto the output stage of the Auralic Vega so that you can plugin headphones on your DAC, you basically have the same thing the Chord Hugo does?
Since I'm not using the headphone output port, but the line out ports on the Chord Hugo like I would use on the Auralic Vega, I don't see the issue here regarding the headphone port that I don't use. It's simply the same signal / output stage you would have used with a DAC that doesn't have a headphone port (even if I would have used the headphone port into the amplifier, it's still the same signal also like a regular DAC)
You can make the bass more pronounced by changing out the stock silver plated ofc cable to a pure copper cable. That's a start.
EQ will help some, but like previous stated, It's the sound of the HD800. You might want to take a journey into planar headphones or other dynamics that do better for bass.
Even my slightly warmer Balanced Beta 22 is still not warm enough for the HD800/HD800S. I would recommend Woo Audio W22. To me, it sounds more pleasing. Tubes really does it justice, but who knows. Added THD may sound fuzzy to you or too smooth.
Perhaps the anaxilus mod might even tame the already tamed 6-7kz peak further in your HD800S where the bass will start to sound more dominating but honestly maybe by 5-10% at most. I recommend trialing other headphones with your current setup. You can always return them. You miss all the shots you don't take.
Hmmm i think mojo alone can not bring magic of HD 800S. Just a few minutes, paired it with hugo tt, it sound quite impress me, but still lack of bass slam.
But too bad, hugo tt is not balanced...
Still do not know what balanced amp that will bring magic to hd800s
That's an understatement. If it's just about the bass, you'll get all you want from equalizing (if done right). Well, I haven't heard the HD 800 S yet, so don't really know how it will react to an increase by say 5 dB at 30 Hz in view of the measured 2nd-order harmonic distortion. However, usual basshead headphones show even higher low-frequency distortion.
I use J-River but the band isn't that large at all. Raising the bars changes the entire spectrum thus no longer sounding like an HD800 anymore.
What do you use? I just want to raise the low end slightly and further remove some sibilance.
I use xnor's graphic equalizer for foobar2000 (1/3-octave/31 bands) – but mainly the 10-band octave equalizer of my FiiO X5 II, the center of my main system.
Here's my foobar settings. Note: it's for a HD 800 classic with damping mod.
I'm quite happy with the Schiit Mjolnir 2 with my HD800 S, balanced. I can't imagine another amp being much better actually.
I didn't think so to until I upgraded from the Mjolnir to other amps. It gets better my friend.
Thanks for the link. Have you tried the Anax mod before (must have) before switching over to this one? Seems like the design is to cover the metal mesh to add more dampening for bass increase lowering the treble slightly i assume?
Have you ever used J.River? If i can't find a way to get more bands on here I'll switch over to Foobar2000.
I've tried other amps including Cavalli Liquid Carbon, Oppo HA-1, Burson Conductor. None of them were near the performance MJ2 with the HD800 S.
That is very interesting. When i switched from Gungnir/Mjolnir stack to using the same DAC, but with Beta 22, it was an immediate difference. Listening out of the HD800 and HD800S of course. There was much more detail, bigger sound stage, punchier bass, and mid-range was more forward.
