AlanU
- Apr 20, 2015
Thanks for the explanation and for helping. In the case of the old amplifier would I just use the headphone output located in front of it and nothing else?
At the moment I'm using HD599 and I want to go to HD6x0 line. On the part of the sound, I'm already satisfied with the treble levels of the 599, I would just like more general body in the sound and more bass, (My ears are more sensitive to high frequencies). I do not know if the hd660 is brighter than the 650, and with that in the general hearing would lose a bit of bass. I'm looking for a softer, warmer sound, a sound that sounds damped and round, like the old speakers of the 90s. That's why I got the 650's attention. If I went for the HD660s I do not know if I would buy the old amplifier since they are stating that it does not need as much power as the 650, would use something more portable.
Look no further the HD650 will satisfy your headphone requirements. If anything the substantially cheaper HE400i would sound more analog and organic for fuller bodied vocals and to my ears sounds better than the more expensive HD650.
The HD660 is "brighter" as it does sound cleaner with some added bass but still not substantially more than "neutral" bass.
I had a pair of Tannoy's that describes exactly what your talking about round and damped with muffled high's. The HD650 is very much like those 90's speakers you speak of The difference is the vocals will be singing directly into your ear canal with small intimate soundstage.
I'm sensitive to high's and the HD650 will definitely NOT aggravate your ears. I'd consider them dark and very small soundstage. The HD660 is truly a breath of fresh air with cleaner sound with some hint of the mash of blended music reproduction of the HD650 signature sound. Your style of music may vary how you analyze the performance of the 650 and 660.
I'd probably suggest buying a dedicated headphone amp that will be much simpler to use with no big concern of impedance matching.
