There is a 1.4m/3.5mm plug cable from Sennheiser, that is/was intended to be sold in a combo with the Apogee Groove. So they don't show it under the 'plain' model listings.
The part is listed as
Sennheiser Article No. 570679
It shows up as one of the available parts under these listings:
https://spares.sennheiser.com/en-us/catalog/product/508526-hd-660-s-apogee
(shows the standard 3m/6.35mm with 6.35/3.5mm adapter and the 3m/4.4mm cables, as well as the 1.4m/3.5mm to go with the Apogee Groove)
https://spares.sennheiser.com/en-us/catalog/product/506971-hd-650-groove
(shows only the 1.4m/3.5mm plug cable under this listing, you have to look at the regular HD 650 listings to see the standard long cable)
Here is the direct link for that particular cable:
https://spares.sennheiser.com/en-us/catalog/sparepart/570679
Connecting cable with 3.5mm plug, 1.40m
That Amazon listing from your link says it's a 1.4m cable, but Amazon doesn't show 570679 as the part number. If your packaging has that article number, it should be a genuine Sennheiser part. I can't imagine anyone bothering 'faking' that exact length when the original part isn't expensive.
Hope that helps! I searched for all of the factory cable options & bookmarked the links when I got my HD 58X, just in case I ever needed/wanted a length or connector other than what it shipped with, but then I got the HD 660S and the HD 600, so I ended up with a few cable options that way!
(What good are extra cables sitting around when you can have other Senn headphones
attached to them all?
hahaha!)
