What do we get if we guess right?
Sennheiser HD660S... Finally a successor for the HD650?
- Thread starter Levanter
Mike F
- Dec 11, 2009
Peace and quiet!
GearMe
- Feb 17, 2013
Will the HD660S stay, or will it go........
Clearly it must stay...if for no other reason than the symmetry on your headphone rack!
(must say I never seen a music stand used for that but to each his own...pretty high tech as well)
Is it easy to replace the grill on the 580 Precision? I don't like the original plastic...
I am voting for stay!
(remember you can't teach an old dog new tricks!)
Nice photo! Is that a more recent HD580 with the metal grill? When I got mine back in the mid 1990's it had a plastic grill. Maybe you replaced it?Will the HD660S stay, or will it go........
Mike F
- Dec 11, 2009
No, mine is also one of the original ones. Bought soon after they came out. I replaced it with the metal grills recently. Standard Sennheiser replacement part.
Mike F
- Dec 11, 2009
HAhaha!
Mike F
- Dec 11, 2009
Just the same as replacing the grills on all the 6 series - i.e. very easy!
Mike F
- Dec 11, 2009
Yes, it's my music stand! They don't normally live there(!), but I thought it would be a good place for the photo shoot!
You should definitely keep it to have the entire collection. I have a feeling the 660S will be the last in the series.
flyer1
- May 18, 2009
Maybe the main thing the 660s brings to the 600 series is it's ability to be well driven by DAP's. Reason enough for Sennheiser to also add a Sony format 4.4 balanced cable. The sound quality I get out of my Sony WM1Z with these makes me believe they were made for eachother Don't believe I would get the same result with a 600/650.
Mike F
- Dec 11, 2009
Maybe the best thing the 660s brings to the 600 series is it's ability to be well driven by DAP's. The sound quality I get out of my Sony WM1Z with these makes me believe they were made for eachother
The thing that has come as a surprise to me is how little difference there is in volume between the HD660S and the HD650 direct from my iPhone. It really is only a matter of one or two ‘clicks’ on the volume control difference. How does an HD650 compare to the HD660S from a WM1Z?
( posted before you edited your post! )
The difference between 660S and 650 is barely a 3db!
pietcux
Hi Mike don't send it back, sign it and then sell it. The legendary Mike F. HD660S Special Edition.Will the HD660S stay, or will it go........
