hi, the hd660s sounds good with metal music coupled with mojo?
I think for metal music you want responses that has good level of 6-8k response, and perhaps on the bright side. I think the HD660S is reduced 7k to provide that peak distortion treble(I'd still recommend you hear it out). I'm realizing for rock 7k is important. It provides the cymbal accuracy and distortion sound peak point sound for that energetic sound.
I think the HD660S isn't that close to neutral after 6k, and there is probably more of a recess after that. 7k level lower than to have lively cymbal type tonalities. Althogh speed is good for rock for separation of sounds, but it doesn't have the peak treble point for the dynamics I find. After all this time, I'm most definate on the point that the HD660S has a 5-6k bump, but not all that drastic of a rise under 5k, or I'd hear severe recess there.
I'm not saying it's terrible for rock, but sayin that rock tonality could be slightly better. If you like rock tonality more laid-back, HD660S should work. I think HD600 and HD800(S) work better for rock(although some may prefer more laid back for rock particularly if they have those old peaky treble recordings). I'm starting to get a sense that for rock you need a bit of leveled treble area with no drop after 6k. You don't want to dull out the rock instrumental dynamics.
It does sound somewhat similar to HD650 in how it suppresses 7k, but with slight 6k emphasis compared to HD650 being more present in the upper mids which doesn't emphasize the 5-6k as much, but HD650 treble comes off smooth due to rising to 5k instead of 6k on the HD660S. HD660S dynamics is similar to HD650 like a veil of sort which I'm thinking is 7k onwards.
HD660S does come off on the smooth side with HD650 being even more to the point of veil, but HD660S does have a slight veil as well due to that drop after 6k. 6k doesn't sound all that peaky, but definately a rise there with 5k(perhaps 5k is more rise, and heard more due to lower level upper mids than the HD650). This is why it's not fatiguing like the HD650, and still on the smooth side in terms of treble response. It just has the 5-6k bump for articulation
