There's no more revealing without treble issues, because the treble issues are part of the headphone and altering that implies altering other sound characteristics. An amp won't have -10dB at 6kHz and 0dB at 5 and 8kHz, for that peak to be reduced, you'll have to reduce neighbouring areas too, despite the fact that they are already depressed in response.
The only upgrade to be more revealing and without the peak is another headphone, and that would be the hd660s. Unless you like the soundstage and then you either endure the peak or tamper with the whole sound by using a tube amp or an overly warm amp. I don't say it can't bring pleasure, but it doesn't mean it's superior and accurate.
I can make an analogy to some Grado headphones, with massive resonances and extremely jagged response. Some take them as very detailed, but it's fake. It's the same case with tube amps or ss amps that tamper too much with neutrality. Maybe they're the best solution for a deeply flawed headphone, but the correct solution is a better headphone.
