MixMasterMan
- Dec 2, 2016
I've never compared the QH4 (or Magni 3) to any higher end amps because I've never had any better amps (the iFI CAN is arguably higher end, I suppose, and I do have that), so I suspect you and others have heard the the HD 650 and/or HD 660S on more refined setups, and that is perhaps part of the difference as well.
This is where I think the differences in the HD660S and HD650 is most noticeable is when different amps are used: HD650 seems to pair better with a OTL or hybrid amp while the HD660S seems to pair good/great with almost any SS amp. Those that like the HD660S are usually using a SS amp while many that still prefer the HD650 (like me) are using a OTL amp and I suspect that the higher output impedance of the OTL amp has better synergy with the HD650 while the HD660S has better synergy with SS amps due to its lower impedance.
With all things considered, I would think that the more neutral set up is the better way (as a base line) to evaluate things like headphones. Wouldn't you agree? Once you start adding things into the chain that color or have better synergy with equipment, it's not an even playing field anymore.
