The hd700 also have a dip at 2-3kHz beside the 6kHz peak. Don't know which is worse of the two (the dip or the peak), but the hd660s solved both, fortunately. The large soundstage of the hd700 didn't bother me, in fact I liked it, but the uneven frequency response bothered me a lot. The rigid tangle prone cable, the screetching earcups. It was a complete failure for me. I sold it rapidly for under half the price since everybody was running away from them, at least in my community. In fact, the guy who bought it did it just out of curiosity, to see how bad they actually are, not intending to necessarily use them as a main device.
What I would really really like now is a closed back hd660s, with a +5-6 dB under 50Hz. I would really put my money in that as a secondary headphone.
Among my friends that have headphones the HD700 is one of the favorites but one thing that all who like them have in common is either a slightly warm SS amp or a hybrid amp.
And that was exactly my point - you don't hear the sibilant peak in the HD 700 (or you don't perceive it as a problem), but many do. I'm just bearing that in mind when I read your impressions of the HD 660 S - not that it too has a sibilant peak, but that you obviously like brighter headphones. Nothing wrong with that, but I have found that I generally don't.....
Something to think about: I had issues with the HD600 being sibilant with its small peak in the 3.5-5khz range but the higher peaks of the HD700 and HD800 don't bother me at all. The HD660S is an over all brighter sounding headphone than the HD600 to me but it doesn't bother me. Like you I like the presentation of the HD650 and its not for the lack of sparkle in the highs but how it does with female vocals, piano and acoustic/woodwind instruments where the HD660S has a slightly weird edge to me that doesn't sound natural to me at times. Also, like I noted earlier the choice of amp has a lot of influence on how on will perceive the HD700 and it seems to apply to the HD650 also. I think its important that ones comment on how a headphone sounds should also include what support gear (DAC/amp) was used, along with the genre and listening level.
@Rob80b, while I don't agree with you on the HD660S on some points I respect that you note what gear you are using and the genre that you are listening to so I have a better frame of reference to what you are saying.
I'd also suggest to many that make comments to fill in your profile (headphones own/owned, DACs and amp, genre of preference, and listening level) so others will have a better point of reference on your comments.
