RuiPP
- Apr 2, 2010
Life's complicated..lol...after my hiatus with head-fi a few years back I picked up the HD700s which in turn replaced my HD580/600s, AKG K701s and my Grado SR325is as IMHO for my preferences the 700s covered all the bases making the rest redundant.
The 800s came and went as well as the AKG K712s..but the 700 were finally replaced by the 800S ...still wanting a secondary phone the Audeze LCD2.2s came in for a short visit, fell in love with the base but where did the cymbals go? and horrible for head banging : ( .....joined the original Massdrops HD6XX on impulse which ousted the LCD2.2s..at least their sound was better balanced and they stayed on ones head : )... although better but like my HD580/600s before them their laid back somewhat forgiving signature really wasn't my cup of tea although I liked everything else about them.
Well impulse got the better of me and another pair of 700s returned to the fold as were a pair of Massdrop AKG 7XXs…these two were much preferred over the HD6xxs, so those went…the HD700s didn’t get much head-time as the 800S were that much better…so they went…..I know….but then I thought I’d give the 650s another try, if everyone is right I must be wrong right . : ( no ….just not for me, if only they had a bit more life to them, tighter better defined base and a slightly more open soundstage they would be perfect.
Fast forward to last fall..well what’s this…a possible successor to the HD650 but with the 700 driver…YES,,,,lol….end of story (for now).
ps...What about all the other alternatives out there...well...life is complicated.
Not my preferred listening device but I did indulge a little bit and have the Sennheiser IE800, a pair of pair NE800M and Momentum ie.
One question to you, why only sennheiser hps have you tried? .....
Guys i have two questions.
First is it there sound improvement with balanced over unbalanced.
Second is it worthy (in terms of sound quality improvement) to change the stock cable with some silver plated cryo treated meteorite forged cable for the 660s ?
Another can of worms...I know folks love to have removable cable but personally I would love to see a hard wired copper connection from the source, amp and heaphones as connections between metals are one of the biggest culprits producing micro-tonal distortion and grain by interfering in the electrical continuity of the signal, unfortunately totally impractical in the real world.
I think it's important to realise that on an amp which has a balanced design (has a balanced output), balanced will always sound better, simply because if you listen to it through the single ended output you will only be using (and gaining the benefit of) half of the amplifier. That much at least is true.
I voted single-ended. One of the major engineers at Benchmark is on record as saying the benefits as oft' advertised simply don't exist....
5. There is another cost incurred by dual-active headphone amps that is not addressed. Headphone amps should have as low of a source impedance as possible. If you are using two amps to drive a channel, you are doubling the source impedance. This will cause the headphones to suffer in frequency response, distortion, and ringing.
I could be wrong but unless one has a true balanced differential design throughout the signal chain there will not be any benefit, in fact even with a true balanced configuration as long as there is no obvious cross-talk it will make no difference to the headphones themselves.
There was a excellent post years ago on the topic.
https://www.head-fi.org/threads/balanced-vs-single-ended-poll.576339/#post-7830520
I had the HDVA600 for quite a while and it was noticeably better balanced. However, the Moon amp I currently have is not balanced and I liked the way it sounded better than the balanced Sennheiser amp with the HD800s and HD650 that I had at the time I bought it.Well as you said, Rob, that really is a can of worms (which I'm sure nobody really wants opening up here). All I can say is that when comparing the single ended outputs on my HDVD800 to the balanced, the balanced do sound better. And not just louder, but better - tighter more controlled (and seemingly a bit more extended) bass, better soundstage width and depth, and better resolution of detail. The difference is not night and day, but it's clearly audible even when carefully matching volumes between SE and balanced.
But..but.. but all amps sound the same.....
