I see you have your Cardas on the 650's. Can you comment on what in your experience were the most significant changes compared to the stock cabel? Personnally I'm a bit afraid that I won't hear jack different.
Hi,
I'm using both a Cardas Clear in balanced configuration with the SR-71B from Ray Samuels (for which balanced gives highest power and best detail), and the Cardas Clear Light (half of the Clear... which is two cables) for a short unbalanced cable to the Schiit Valhalla (Single-ended Triode, Output Transformer-Less design which by definition gives the most vivid SET type triody goodness by NOT being balanced). Two polar opposites of amp virtues and both fully justified in their own ways.
My experience... it has been a while since testing the stock cable, perhaps a couple of months... is that definition is greatly diminished with stock. The stock cable is like the stage is in a fog, and the back half of the orchestra is hardly visible at all. Just a metaphor. Also, transients are softened, treble is too relaxed and poorly defined, and bass doesn't have control, depth, and authority. The legendary "veil" (most of which was banished by an improvement to the HD650 about 2007) remains only to the degree that the cable causes it.
I've also added a Moon Audio Blue Dragon v3 as my 1/8" interconnect from DAC to SR-71B, which compared to $10 and $25 cables is much better, clearer, defined, and realistic.
With the Valhalla, I use very good Cardas interconnects from a decade ago (Neutral Reference), which make a nice difference compared to cheap Audioquest, older Cardas, and lesser cables. These combinations of relatively pricey cables with a budget but excellent amp is not wasted... it is just that the Schiit Valhalla is a great amp for high-impedance, medium efficiency headphones and listeners who appreciate the triode purity of sound.
The difference between the two Cardas HD650 cables, Clear and Clear Light, should be mostly a choice of whether the Clear is usable in a given application (it is twice the copper) and if the last bit of additional clarity and solidity is worth the big price difference.
