Sennheiser HD650 & Massdrop HD6XX Impressions Thread
Jun 13, 2022 at 10:29 PM Post #45,031 of 46,499
Definitely enjoying HD6XX with the Custom Cans UK modifications: 8F2ADAB2-65E3-4379-9F8B-3F3455564ADD.jpeg[Norne Audio Vygarde h/p cable]
Wow! Is that Quicksilver a new addition for you?
Jun 13, 2022 at 11:08 PM Post #45,032 of 46,499
Jun 16, 2022 at 4:43 AM Post #45,036 of 46,499
Peeps, over in Europe we're unfortunately running out of the last stock earpads :\ Was told along the lines of foam production being reliant on oil is in far from a good place right now. Sennheiser and Thomann are the usual shops for me but also others that I approached are exhausted. For the time being I'm looking for quality replacements a la eBay and AliExpress that are sonically hard to distinguish from the original Senn pads. Dekoni, Yaxi, ZMF pads and the likes are not of interest.
Recommendations?
Jun 16, 2022 at 8:37 AM Post #45,037 of 46,499
Recommendations?
The new ZMF Suede pads are supposed to be sonically identical while lasting a lot longer than the original pads. You should probably reconsider them given how dependent the 6XX/650 is on its pads for its sound.
The originals wear down after around 18 months.
Jun 16, 2022 at 11:58 AM Post #45,038 of 46,499
The ZMF Suede pads are an excellent alternative to stock. It's not exactly identical sound, but to my ears the ZMF pads give a more dynamic punch and clean up the bass a bit, while still retaining vocal warmth and intimacy. The angled pads also help increase the soundstage a little.
Jun 17, 2022 at 11:47 AM Post #45,042 of 46,499
Yeah, very aware of the influence of earpads. That's why I'm so set on getting originals, or if not an option as close as can be at who knows a way better price. FWIW, had the chance to get a close look and listen to ZMF's perforated lambskins and the material is impressive. They should be at 2.5 times the price to pay for import, which kind of makes buying new a bridge too far. It's duly noted. Might try a second hand pair at some point. For now I think I'll just get a bunch of cheap Ali pads and start some comparisons.
Jun 17, 2022 at 9:06 PM Post #45,043 of 46,499
I just bought a 650 and am using it with a Bifrost 2 + Asgard 3. I'm really disappointed in the lackluster bass. I heard through others that it was supposed to be good, but I don't find that to be the case. The sound is otherwise great, but I may as well listen to a couple of bookshelf speakers across the room with no subwoofer.
Jun 17, 2022 at 11:03 PM Post #45,044 of 46,499
Time for a different h/p/a partner for HD6XX** and the 🎼🎵plays on…😌
[** Custom Cans UK cnc nickel-plated back-weight, driver foam removed, earside foam replaced, acoustically transparent material]
Jun 17, 2022 at 11:31 PM Post #45,045 of 46,499
Of the Schiit h/p/a that I have used, the best match with the HD600 / HD6XX is Valhalla 2. The next best match is Lyr 3. First is all-tube OTL; second is SS/tube hybrid.
