castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
I have justified issues with listening experiences not limited to listening and trying to define the reality of sound changes anyway. I also have a problem with how hard it effectively is to do a proper A/B of cables, given the time it takes to swap them(more time means more involvement from memory, which in turn means less accurate stuff. that makes me very skeptical about the accuracy of such anecdotes, I'm not going to lie.Well, with the HD 650, I can hear a clear diference between this thin cheap copper cable: https://www.ebay.nl/itm/Replacement...606101?hash=item468f1ac195:g:9TgAAOSwhr9cVeyg, the stock HD 650 cable, and Mogami 2893 copper wire.
With the thinnest cable producing the least bass, most distant mids and most uncontrolled treble, and the stock cable makes it fuller and more refined vs the thin ebay cable, and then the Mogami makes it fuller and more refined vs the stock cable. I did compare them multiple times, and to my ears it's clear that there's a difference.
I think it has to do with EMI/RFI interference resistance of each cable.
now if for some reason I don't know about, you have justified confidence that you're really getting those changes in the sound itself in the ways and proportion you discuss, then the right conclusion is that those cables are the cause(for whatever actual reason TBD). I'm not trying to get into a "all cables sound the same" type of debate. just one where we try to fact check what we experience, and where we discuss electrical appliances in a way that doesn't go against electrical rules.
as for EMI/RFI, again I guess anything is possible if we stand next to machines generating massive amounts of those waves or fields. but in typical real life experience, the quantities you would expect to pick up with a cable are not scary at all. even less so for a HD650 which isn't all that sensitive in the first place, so whatever noise has to reach a high enough voltage to even have a chance to get audible. maybe with some extremely sensitive IEMs that end up making a same voltage 10 times louder or more, we would be more likely to encounter situations where EMI or RFI do matter. even then I'm not sure how audible that would be in a normal environment, I remember going mad passing a security door with some IEMs in my ears and a given cable was clearly making it worst, but we don't usually spend our days inside security doors with IEMs on ^_^. anyway, back to hd650. while I don't know your listening circumstances, where you live etc, and don't want to claim something without proof, I at least wouldn't put EMI or RFI and how cables handle them, at the top of the probable causes making that headphone sound different for you. IMO those would be way down the list of likely causes. even more so because those stuff would logically generate noises, not boost the bass or change the signature. those stuff would require another type of electrical interactions(mainly EQ I guess).
