Because of a Massdrop, they aren't making cables other than for Massdrop customers.
Ah, that sucks. I didn't know that, I guess I was lucky as I received a new delivery from them last week.
Sorry, here are a few more.The cable without the XLR is not balanced and the XLR is not what I want. Also, they don't say what type of cable. So no go.
Can you do some basic soldering? It might be cheaper to just build your own balanced cable with the 2.5mm TRRS jack. The Eidolic 2.5mm TRRS is $11 from Double-Helix and you can find Cardas HD6XX jacks for $10/pair, add some Mogami cable and a 1.4m cable could be built for under $30, granted it might not look the best but its functional. One thing you might want to consider is to get a 2.5mm TRRS to 4-pin XLR female then you can get other balanced cables that have 4-piin XLR jacks to what ever headphone you are using instead of trying to always find the 2.5mm TRRS jack to headphone jack combo since it might be harder to find.All but one of those links have the appropriate cable. All the others that do use XLR. I don't want XLR and the one site that has the correct cable is charging too much.
Most of the cable makers in the links should be able to make what you need if it is not listed. Have you contacted any of them about your needs ?All but one of those links have the appropriate cable. All the others that do use XLR. I don't want XLR and the one site that has the correct cable is charging too much.
Agree, I've notice that anytime a headphone that goes on sale the thread for that headphone gets active for a few months with many new owners and then slows down or its a new product that is a good value. Seen this with the HE400i, HE560, Hugo2, M1060 and some of the newer DAPs. This thread will probably pick up when the HD6XX starts shipping in DecWow I'm amazed at how inactive so many popular threads have become since they went to the new format (website).
