Rob49
Pleased to hear, it's that way round !
The process is fairly simple and straightforward. You'll need to harvest the rings from the old pair of pads. Just cut them out carefully. You can reuse the old foam that goes against the drivers. Insert the rings you harvested to the inside of the pads. Put the foam over the foam and then gently but firmly pop the new pads into place.
PLEASE be carefully when pressing firmly not to dent the grills.
All this sounds complicated until you've done it once, then it's easy. The hm5 pads are thicker and will require some convincing to get to snap it place. But that's it. I really do love the hm5 pads on the 650. Thicker, more cushion and IMO sounds better.
That's great, thanks for the detailed explanation. I've been meaning to replace the earpads on mine and was just going to buy the stock ones at over $60/pair (CAD). This is quite a bit cheaper and if it sounds better, than that's even more of a deal.
So does the link I referenced seem to be the same ones?
I'm surprised that the hm5 pads don't raise the bass actually. Or at least the mid bass, or is it the velour ones that you're using?
I can't believe some people are removing that "plastic spider". It's pretty obvious what that is, if you have any common sense that is. It's a very important structural element that makes the entire driver assembly stiffer, keeps the magnet securely in it's place and enables the dampening foam to be secured above the hole and give the driver an optimal amount of airflow on top of that. Removing that can only hurt the sound and in the long run reduce the reliability of the headphone because now the only thing holding the magnet in place is a little bit of glue. The diaphragm of the driver vibrates in a very precise way, and in order to do that, the structure it's attached to has to be as solid as possible. Making it less solid can't possible improve the sound, if you do hear an improvement, then it's just placebo because you want to hear an improvement.
I still don't understand how people think they can improve the sound by removing pieces off a headphone that are there for a very good reason. People who developed these headphones know infinitely more about engineering and acoustics than you do, so don't insult their work and intelligence by claiming you can "improve" the headphones by doing these mods that literally do nothing else but ruin the original state of the headphone. You're not improving them with "coin mods" or removing the foams, removing the structural elements, or doing any other think that goes against logic and common sense when we're talking about acoustics, you're making their sound more uneven and taking them further away from what they were meant to do in their original form. They don't sound the way they do by accident, they were designed that way.
I'm sorry for being this direct, but the amount of false science on this web site has reached intolerable levels, and it will literally make some people ruin their headphones after reading some of the ******** around here.
As I said...."never being satisfied" lol
"but designers don't always get it right".......but what IS right ! ?? ( When as you imply, all headphones are different & "none of them are right really" ) I would rather go by the conclusion of what my ears indicate, rather than a measurement. ( With all due respect ! )
Enjoy your listening.....and to any "compulsive modder", I hope you find the time, to do just that !
There are people out there who wouldn't even consider using EQ but will happily take a knife to their headphones.
EQ doesn't do anything for cup resonances and isn't portable, so it has its disadvantages too. It's also quite common for eq to be applied in the wrong place or have too much, which is why commercial software like Sonarworks is effective. It is based on measurements and not just by 'ear'. Bad EQ is no better than a bad headphone really.
I'd only consider modding if I felt that the 'problem' warranted it myself.
I did feel that lumping all modders into one box of obssessives was simplistic though and is the kind of attitude that imo actively tries to stimulate a typical, daft hifi argument.
but I think most get in to modding due to a short coming of the original designers compromise due to cost or engineering difficulties.
Sorry for the rant, have a slight hang over this morning and had to walk the dog since the GF is still sleeping
I'm one of them, lolbut so far only been "operating" on:
Sony (MDR-1A-dynamat in cup, close off part of top vent)
V-Moda (Crossfade LP-new drivers)
Fostex (TH-600-dynamat in cup, removable cables)
Grado (SR-225e-wood cups, dynamat, sorbothane, felt, new cable: RS2e-new cable)
Stax (SRD-40-new mount for different ear pads)
Beyer (DT-990 premium, T1-removable cable for both)
Hifiman (HE-400: grill, dynamat and headband; 400i: grill; 560-grill)
Haven't touched any Sennheiser except for PX-100ii for SennGrado build.
I agree but these people do exist. If someone's paid the money and they want to butcher their purchase that's fair enough but to do so without at least attempting EQ first is madness imo.
