pietcux
Thanks for the suggestions. Was actually thinking of Oppo PM3.
Hope I dont get zap by 650 lovers here..ha ha
You could get yourself a used HD800 and call it a day!
is this normal? the right side of my HD650 doesnt adjust up as high as the left side....the right side stops much lower...here in this pic i have them both pulled up as far as they go and the right side is significantly smaller...is this a defect or another one of those pointless german mechanics that have zero practicality but everyone praises cus BMW vanity > honda ? jk lol
but srs, is this normal?
No, this is not normal, my HD 650 does not have this defect. And if you inspect the headphone a little more carefully, you might find out that they are made in IRELAND, not in Germany.
is that ok? or do i need to RMA them? i mean they fit me comfy and any bigger would be too loose...
Send them back ASAP. This will cause channel imbalance.
jk
well obviously i was referring to them being designed in germany... You may also be shocked to know that most BMWs in the US are made in south carolina...
shoot what should i do?
i mean i can adjust them evenly, i wear them both on the 7th click from the bottom on each side and they are even and nice and comfortable...
but after the 8th click the right side stops and the left side goes up to 12 clicks before it stops...
but im glad my 650s arent defective, they are one of the few things i have in lief keeping me together.
Yes, width. Also for me, everything that my floor system does very well: depth (the trumpets and oboes MUST be well behind the cellos and violins) and separation. 650 does very well with smaller-scale chamber (as I said), but when multiple groups of instruments are then added and play together, the 650 loses it. I hear everything, but in an almost homogeneous flattened image. Weird. I didn't get that with T1 (used to own T1), LCD-2.2, and now, my HE560 does it soooo well. The PS500 also does classical better. Not knockin' the 650, for everything else, it's great. Just not large-scale symphonies like Schubert's 9th or anything dynamic written by Ludwig.
cheers
Any specific smaller-scale chamber music you would recommend to listen on the HD650 to?
Get over to this thread, not here:
http://www.head-fi.org/t/626563/best-classical-recordings-ever/7485#post_12292449
(Everything and anything....for chamber. Beethoven's Horn septet/sextet, Mozart's wind concertos, Haydn's String Quartets).
Will do. Apologies for not following forum etiquette.
