castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
Does it make sense that the Magni 2 Uber would only need the volume turned up slightly to power the 650's well? Starting at 7 O'clcok (all the way down) and turning it up very slowly, you hear the right speaker turn on right away, quietly, and then the left speaker comes on well before you get to 8 o'clock. By 9 o'clock, the headphones are about as loud as I'd ever want to listen. All the way up would be 5 O'clock, and i imagine the headphones would be totally blown and ruined if I ever turned it much past 12 or 1. Never tried as I don't want to risk it. Does this sound weird to anyone, or normal?
it's perfectly possible. but we would need more information to estimate how loud the hd650 is going. the DAC used(if possible the max voltage output of said DAC), if you're on full volume output both in your player and computer? if you're using replaygain or not? the kind of music you're listening to(some old stuff are recorded quite low).
or much more simple, if you have a multimeter to measure the output with a test tone. I just tried very casually and without much care, on my ODAC O2 I have set the computer and foobar to max loudness, using replay gain(I disabled the EQ for clarity of the measurement done). I set the amp to ok loudness(not as quiet as I use for long relaxing listening, more like reasonable loudness to enjoy one or 2 songs. I end up with 0.02V, so that should be close to 69db loud @1khz into the hd650. and I'm on gain 1X with the O2 around 8 o'clock. so with the modi low gain being X1.5, if your DAC is also around 1.5 to 2V and the knob course is similar on both amps(a lot of conjecture sorry^_^), then that seems possible indeed. I would suggest to lower your player's volume by 10 or 15db so that you can get at a more comfy position on the amp.
