whirlwind
What's wrong with USB powered DAC's?
Well mainly they are at the mercy of the power supply of the laptop or PC. If it's a good well regulated supply you should be OK, if not the voltage to the DAC can vary depending on how much of a load the Laptop is under. Lord knows what audible effects there could be if the USB voltage is being modulated by the varying activities of the Laptop.
Just about any amp will in part be judged by the size and quality of it's power supply, it all begins there. Would you be more comfortable having your DAC/HP Amp powered by the wall wart that powers the whole laptop at the same time or would you rather have a power supply for the DAC/HP Amp only that looks like this.
As for my comment on battery power, your probably better off with batteries than USB power, at least the voltage won't be affected by anything else besides the DAC-HP Amps own load. But I still feel the larger and better regulated the power supply is the better off you be in the long run. Just MHO and lots of possible variables involved too.
I agree with having a very nice power plant in your units.
You want to be able to handle the voltage swings in a high impedance headphone.
