Hey guys. So I auditioned the HD800 along with some other high-end headphones today, wanted to share my impressions and compare them to the HD650's.
The audio chain was a Meridian Director DAC into an HDVA800/Oppo HA-1. This setup costs as much as makes no difference $3,000. This is as good as its going to get in terms of amplification, and I'm comparing it to my $600 setup - just something to keep in mind.
Auditioning headphones with music that isn't your own is always confusing as you don't know what to expect, luckily though there were a lot of songs that I know and have heard many times.
1) HD800: Where do I start? This headphone really ticks all the boxes. The amount of detail is astonishing. As cliche as it sounds, you really do hear things you've never head before. The overall presentation is wide and spacious, everything is spaced out and every instrument is easily distinguishable from the other. The bass decay is QUICK. Drums and kicks had a lot of authority. Its bassier than I thought i would be to be honest. It had a lot of subbass, but very textured and tight. They have the same magical quality to the mids as the 650's have. BUT, here's the thing: they were not as musical as the HD650's, I also felt like the 650 had a bit more weight to vocals (particularly male vocals). Make no mistake though, the HD800 is clearly the superior headphone sonically, but the difference is nowhere near as the price jump may indicate. If I was to upgrade (which I probably wont, and I really mean this), this would be the headphone I would choose.
2) HE-400i: Ok, we've toned the price down a bit and this is becoming a better comparison. We're still on the same DAC/Amp though. The HE-400i was a kind of bittersweet headphone. I have a love/hate relationship with it. Firstly, the bass was perfect for the price range its in. Very tight and texture, with fast decay and a lot of impact. However, everywhere else, I found the HD650 to be better. Firstly, the Senns clearly had better mids. More forward, smoother, and more detailed (as crazy as that might sound). The sound is thicker on the Senns. I also think the HD650's have superior imaging and soundstage depth and layering. He-400's were noticeably quicker, with more detail in the highs and better extension, also better bass. But I also found that it doesn't quite have the transparency of the Senns. This is a side-grade to the HD650, not an upgrade.
3) AKG K712: I didn't spend much time with this headphone as I had to go, but with the time I had with it I was impressed. First, let me tell you that I hated the K701. I found it much too thin and lacking bass. It was not a musical headphone whatsoever. However, the K712 seemed to improve upon that headphone. First, I don't find them particularly lacking bass anymore. Sure, they could use a bit more dB's in the midbass but not much. The shoutiness in the upper mids is gone, the treble was smoothened out, and strangely the soundstage got a narrower? The AKG is a quicker headphone. It has less bass impact but a bit better extension than the HD650. As always, the HD650's mids do beat it. Sometimes the AKG's vocals sounded a bit raw, on the contrary the Senn's mids are much smoother and more intimate. I also feel like instruments sound better on the HD650's.
I've made the same writeup but with comparisons to the DT880, you can find that on the DT880 thread if you want to read.
