CanadianMaestro
Wrong thread for this. Get over to the HE400/LCD threads for this stuff.
Man they really stick it to you on their "money back guarantee" 15% restocking, on top of the shipping you had to pay, and you have to pay to ship it back. I might be better off putting it on craigslist.
I think I know part of the problem. I've been comparing the specs and the DAC chip they have in the Modi is decent, same class as the E5, but it outputs 1.5vrms. All of the DAC's people seem to rave about have 2 to 2.5vrms out. I suspect that the Modi is under-driving the preamp on the Lyr leading to mud. I can't find the specs on the E5's line out voltage but hot swapping using WASPI push at max volume, the Soundblaster is louder than the Modi. If I had to guess I'd say it's 2vrms to the Modi 2 ubers 1.5. This puts it on par with the Bitfrost.
I think I'm going to just have to bite the bullet on this and buy another DAC, I didn't spend half a grand on an amp to have the DAC make it sound like poo.
I'm thinking to get the musicstreamer ii plus. I've seen several recommendations around the board and I remember looking at those before I bought my Audioengine and hearing good things. It's $250, asynch, outputs 2.5vrms and has an isolated analog stage to keep usb noise out of the signal path. What do you guys think? I admit I dind't research Modi 2 reviews much before buying. It was only $150 and at half the price I was impressed heavily by their Fulla.
No worries. I've seen worse.
It's too bad the pads on the 650 can't be experimented on (switched out). Short of cabling tweaks (not keen on that), and amping (have 3 of da best already), I'm not sure what else to do to bring out more micro-details. Not day and night, like I hinted at. I guess it's expecting too much to have it even close to a planar mag like LCD-2.2. Must be my Sunday afternoon brain haze and delusion.....
Thanks for your insight!
I have learnt so far that HD650's seem to enjoy voltage more than current. I don't know what this means in terms of electronics, but I guess I can't go wrong if I chose the amps which have good voltage output.
I use an output modded O2 (so it can squeeze itself closer to a 15V output), and have been pretty happy with the results, details are - at least to my ears - quite good. Though of course I can imagine other amps which can do the HD650's plenty of good.
Right now my next amp is a fully DIY one (apart from ordering the board) called the SeNNator, which is designed specifically for the HD650s'. Currently awaiting two deliveries - I always miss out a few things - and I may ,with luck, report back in this coming week!
As for frequency response from this amp. I don't know how to get the most out of this chart, but these are the measured results that I should expect:
Red: without
Green: with
It says kameleon, but the filter design remains the same as far as I understand.
I guess I am quite envious of those whom are able to hear micro-details, and rather fortunate (pocket wise) that I am slightly impaired to them.
Tinitus seems to save money..
I know that with the right amp, the HD650's have amazing tone. Micro details with a HD650's is something I haven't really looked into, which now piques my interest. How does the HD650's represent these details with those set-ups?
maybe I'm missing something, but couldn't it be done with a good EQ?
Some players have reasonable performing tone-controls/equalizers that can be used to (partly) correct the tonal balance of the connected headphones. Most tone controls/equalizers are limited in frequency bands/bandwidth to provide accuratecorrections. Rockbox has one of the few quite usable parametric EQ with presets and works quite well. Software equalizers do add artifacts and/or noise and exhibit pre-ringing inside the audible band. You would need to create presets for individual headphones based on frequency plots of headphones or 'by ear'. Most audiophiles shiver when they hear the word 'EQ' and with good reason as EQ certainly cannot solve all technical problems / shortcomings, but it can improve tonal accuracy.
Analog filters have certain advantages over digital filters, amongst them no pre-ringing and less distortion.
This thing about the Modi 2 Uber is interesting to me too. Not the financial side of it really because at the moment I'm skint but the sound quality angle. I use an ODAC & since I've now upgraded to the Project Ember Mk2 amp I'm hearing what's often referred to as the achilles heel of the Sabre chip - namely treble glare.
On another forum I'm active on I've asked around & the general consensus has been that, for the price, I should be looking at the Modi 2 Uber.
Given that Kodhifi hears "mud" from his DAC and I hear "glare" from my DAC I'm now very confused. Is it just perception? Is it a mis-match of components? If we lived on the same continent I'd be happy to swap for a time to see what the issue is but that's not going to happen.
Here's an off-the-wall question..
I read some posts back that the only difference between Modi 1 & Modi 2 Uber was the "enhanced analogue circuitry". But there's a more significant difference than that. Modi 2 runs off mains power as opposed to USB.
Is it plugged in to the wall mate?
Gordon.
I didn't say anything like that and I don't believe that only expensive is good.
On the second item, I didn't comment on the sound or quality, which is NOT fair game if you don't own one; I commented on their return policies, which are clearly documented on their web site.
I offered my $0.02 because, well, you asked.
EDIT: typo.
I believe that "laziness is the mother of all invention", is an overkill of a statement right now..
I believe Frans has said something upon this matter. Being a complete lazy bum that I am. I have copy/paste 'd the section from his Kameleon amp documentation:
