Sennheiser HD650 & Massdrop HD6XX Impressions Thread
Nov 17, 2014 at 7:15 PM Post #20,372 of 46,533
I don't see how balanced really helps these cans.  I've tried running them off balanced sources, I have an audio interface and a balanced mixer and I butchered a cable for the HD650 and did a Dual TRS connection and couldn't tell much difference other than maybe a little less crosstalk
Nov 17, 2014 at 8:45 PM Post #20,373 of 46,533
I notice differences on my setup between SE and balanced not a huge difference like I hear with HD800, but it is a better presentation overall HD650 balanced
Nov 17, 2014 at 9:12 PM Post #20,374 of 46,533
Better channel separation and better defined low end are the main differences. If you have the option, use it.
Nov 17, 2014 at 9:40 PM Post #20,377 of 46,533
I've heard that if you run the HD 650 in balanced mode on the Sennheiser amp, the results are amazing, like taking your headphones out of the closet and hearing them out in the open for the first time
This is exactly my experience.
Nov 17, 2014 at 9:45 PM Post #20,378 of 46,533
Try the same amp in SE and then in balanced. Then do it blind. Then I'll have more evidence.
Nov 17, 2014 at 9:46 PM Post #20,379 of 46,533
I'm willing to bet most differences between balanced and SE are placebo.
Nope. With my LCD-3's balanced made a nice improvement but with the 650's it's the difference between a good and a great headphone.
Nov 17, 2014 at 9:47 PM Post #20,380 of 46,533
On the same amp, or one amp was SE and the other balanced?  Because different amps would make a big difference.
Nov 17, 2014 at 10:18 PM Post #20,383 of 46,533
Volume matched?  Because I'm a skeptic at heart, but this intrigues me.
As close as possible. I resisted balanced for many years but finally broke down and tried a Mjolnir and have been hooked ever since. For the 650's the Sennheiser amp is a double benefit because of the synergy and the balanced option.
Nov 17, 2014 at 10:39 PM Post #20,385 of 46,533
from one good flat low impedance with enough power SE, to one good flat low impedance with enough power BA, I am totally with you. and I wouldn't tell people to get a balanced amp but just to get a good amp for your headphone, whatever the circuitry.
but from the same amp in SE and in BA, I have always experienced a good deal of change. that I attributed to the SE being bad, or a big impedance or crosstalk change. still, whatever the reason I also felt as if there were differences.
  • Back
