grrraymond
- Oct 19, 2010
Pretty good though, eh? I actually bought a second hand pair for about £150 and have since replaced the headband pad, discs and earpads. Had I known etc.
I will be transporting my HD650 between work and home. Was wondering if any of you have a headphone case, or could recommend one?
there should be no problem if it fits the 701. I think it'll fit, and hope it goes good for youI have a large case labeled "V-Mota" with a Koss logo on it that I got from ebay. I fits my Q701 easily so the HD650 should be no problem.
HD800 are for use at home not as portable
The IE800 is Senn's top in ear....
The HD800 is Senn's top headphone...
I own hd650 and momentum. I'm really interested in getting the ie800 but not sure if I will like its sound . I've got the impression it's very bassy and I find the hd650 about right in the bass but the momentum a bit much. How does it compare ? Also are the microphonics and issue? I would be using for long dog walks mainly .
I just received my 650's, which are my first pair of Sennheiser's, something I have been looking forward to for awhile after seeing all the praise here on Head-Fi. My immediate impression is that they sound great. I'm just using a cheap little SMSL that I just got, so not sure if I'm getting the full effect yet. Later tonight I'll try them at home on my Bifrost + Vali combo, and see how they sound there.
One thing I'm noticing right off the bat tho, if I have them actually sized to fit my head snugly, they REALLY hurt at the top of my head. I have to loosen it up a bit, which isn't really a problem, just surprised me how tight they can be when actually fit to size.
I have pretty big head (please no jokes) and my 650's are extremely comfortable. It took about a month of use (2 hours a day) for them to loosen up, enjoy!
