SomeGuyDude
- Jun 24, 2012
I was genuinely surprised with the HD650s off the Verza and an iPhone. I don't think they need anything else, and I never pushed them above 50-60% volume.
I'm listening to my HD650 using my X3 as USB DAC, FLAC, Joe Bonamassa low gain, volume only 26. Full pelt it should give around 115dB - but I don't want to damage my hearing
Sufficient Volume doesn't equate to a good amp for HD650... just as sufficient volume for earbuds doesn't equate to good sound.
However... the HD650 are really not as unforgiving to drive as some of us here say. In truth, most amps can make them at least pleasing to listen to. Yet, as we all generally agree here, the HD650 scales up very well with good amps.
As with the others here, if you have $500 to spend I'd say get some Schiit(DAC and amp)
Coloured, lush, rolled off highs, poor bass all seem a common perception with tube amps.
Safe to say my Crack sounds nothing like that, its more engaging, fast, dynamic & natural!
Upgrade to some film caps and a stepped attenuator plus a couple of $3 Russian surplus Teflon bypass capacitors and you can add refined, detailed and highly resolving to the list. all for less than $100 extra.
By the way the Crack has just gone straight in on the new wall of fame for amps at Innerfidelity.
Audio stuff seems to be filled with 50% folklore and 50% science, with almost 50% of it being a blurred line
Mine is a Valab 23 step 100k ladder type, it came with all the resistors fitted for around $30 if I remember correctly, very happy with it and a noticeable improvement over the standard Crack pot.
do they make log curve stepped attenuators, or do you have to buy an empty one and do the math yourself when picking precision resistors?
