- Oct 31, 2010
For me HD700 and 800 have bass as good as HD650 but have better instrument separation and details retrieval plus wide soundstage then HD650
Does anyone have an upgrade for the HD 650, other then the LCD-2? I'm looking for something like the hd 650 but more controlled bass and non recessed mid range. LCD are just to heavy for me even though I love the sound and think it would be the best upgrade headphone. Thanks. budget 1500ish.
That's y I am using a silver plated copper cable on the hd650...
It's like a hd600 with more bass...or a more alert hd650.
BeyerT1 is awesome but expensive.
The ATH W1000x would be worth considering it is very good, not so well know on head-fi. $419.00 on Amazon it is low impedance so much easier to drive.
What amp are you using to drive the 650's? This might be hampering the performance of your HD650's if its not the best of matches. The 650s scale very well and if your not driving them adequately then a switch to say T1 with the same amp could be very disappointing. Some thought on amp matching is required for the higher impedance cans to perform at their best. There is quiet a difference in performance if miss matched.
The bass extension on the W1000x is really bad, for someone who likes the LCD2 sound signature, IMO.
