FastAndClean
Previously known as presata
only the upper mids are recessed on HD700, the lower mids are actually forward
I don't honestly know. The pair of hd700 I'm listening too are very vocal forward. The only thing I could think is maybe the sample rate? I have mine at 32/384. It shouldn't make a difference but its not a common rate. Also what setting do you have your amp on? What is the max power it can push ?
For me this is a good track to test major factors of a headphone. First 20 seconds you can tell if the headphone will hurt your ears. Then you hear the bass and can determine how the headphone does with bass. The guy's voice is low and a little mumbled by default so you can see how the headphone handles that vs background music. Using my pair of beyer 990 his voice blends in the background. With HD700 it shines above everything.
Edit: So I looked back at the original post when I bought the hd700 and it appears they had the "Mod House Audio mod" installed. I know nothing about what was done, how it was done or what it impacts. This could explain why I'm hearing something completely different from other ppl.
Quite possible. Have you heard the LCD2, HE560, or HD650? These all have a more classically linear frequency curve.
The HD700 departs from this somewhat, which gives it a unique sound - one some people can find a bit hollow or not as full. Personally I find it strikes a great balance.
I just looked at the Mod House Audio graph on the changes and it shows quite a big boost in the mids and upper mids/lower treble along with a large reduction in the 4.5-7 khz area so I would think its a very different sound from a stock HD700 and probably why it sounds better to you on a SS amp.Is this a joke? Her voice is #1 thing I hear, heck #2 and #3. I could probably EQ the vocal range down 3-4 dB and it would still be the most forward thing I hear. I'm honestly wondering if HD700 had different batches of drivers.
I had the mod house audio mod on mine for about 3 hours and removed it. Imo, it sucked the life out of the 700's. I did not like it at all.
It's very easy to remove if someone has purchased a used 700 with it installed.
There are a few SS amps that are slightly on the warmer side or neutral and work quite well with the HD700 IMO: Teac HA-501/UD-301/UD-501/AH-01, Project Polaris, Hugo, DarkStar, Liquid Carbon and a few others.Yeah I would agree with this. I have a magni 3 modi Uber 2 I'm about to experiment with. So far I've pad rolled with Chinese offbrand pads, and the velve material actually brings out the sound even more. The audio house mod does kind kill some of the high deliciousness, but it does bring out the mids a bit more. Imo I think most people can't handle a SS amp with the HD 700s since they get fatigue fast, so they resort to a warm tube profile to balance it out. Otherwise audio house mod with SS imo should be enough for some. I just got my pair so I'm about to try that out.
The stock HD700 cable has been known to be very kinky to start and I was never able to get them to straighten out so you are not the first to complain about it. As for a good stock cable the HD650 stock cable is not bad but if you are going to get your friend to change the connectors why not get a cable that has the HD700 connectors to start? Since I've yet to hear a headphone cable that makes any sonic difference I just stayed with readily available Mogami, Canare or Van Damme cables when building my own.Can someone name a good stock cable? Doesn't matter what company or what type of connections are on it. When I bought the HD700 the person tightly wrapped the cable around the headphone. Now its a nightmare that constantly gets tangled. I want to sent a stock cable to my friend and have him put the right connectors on it so it will fit my headphones.
