- Oct 26, 2008
Between WAV and MP3 256vbr all the time, between WAV and 320cbr, it depends on the song/recording
listened to spotify and tidal premium on a friends system, didn't like either, something missing, like you are listening thru a filter.
Easiest to notice differences in sound for me is on HD-800 and SR-009, bad thing is sub par recording really sound like S _ _ _.
I'm with you. between flac and a good 320mp3 it's not as blatantly different as I thought it was, and it really depends on the quality of the recording. On really well recorded stuff I can pretty easily pick out flac, but on a lot of garbage recordings, I have a pretty hard time.
Probably both..haha
Can you at least tell the difference between Mp3 vs Flac vs Lossless ?
How about DSD vs 24/96Khz vs 16/44Khz ?
or Spotify premium vs Tidal premium ?
It's a curse for me cuz most of the time yes I can ..lol and due to it's higher resolution HD700 is a great tool to analyze these
You can hear the difference between Flac and lossless?!
There's a great tool in Foobar you can add on and test your ability to differentiate in a blind test. It's a great way to figure out if you're hearing a placebo effect or not.
Way more importantly you'll learn what to focus on when testing and you'll really sharpen your skills.
Just got my new amp to power the HD 700, the Rag.
It is a slight upgrade from my Vali. But after I auditioned the Airist Audio amplifier I new I needed a better amp for my HD 700. It will be interesting to compare the two amplifiers. I really liked the soundstage of the Airist but though it was not quite as powerful as one would expect. The Rag on the other hand has way more power on tap but initial impressions of the soundstage is not as wide. But I will reserve final assessment until the Rag has broken in with the HD700.
I shudder about hooking up a pair of HD700 to a rag. Isn't the combination too bright? Have you modded the HD700 at all?
