Found wood cups in closet from old build.... (this is a pic of old build below)
So, thought i'd bolt them on the 580 . Not my idea, some guy on another forum bolted amaranth (Kennerton?) cups on his 650 (pic below)
Sound Impession: similar funny enough, but leaner and sharper.... eek...
Oh yeah, they're open back, and now closed, so velour pads work no more......
Slapped on Meze 99 Classic pads.... pleather .... made for closed..... Hey this is not too bad at all.....
Ok time to swap it back to original and move on with my day....
But I'm come this far.... should I ... try on ... same baffle essentially right??
Bolts on... check...
Meze 99 Pads check....
and... we reach here...
Wowey, these don't sound like Sennheiser anymore. Reminds me of Dt770 80 ohm but with tamer treble, and slightly more forward mids, and perhaps a touch less subbass, but the midbass is full force and makes this a very warm listen.
I wouldn't really tell another person to go through this. If you're curious what these are, they are Fischer Audio Fa-002 cups. They basically just bolt on with 4 screws. I believe the Kennerton (same company or parent company) make the Magister cups or similar (pic above with red cups on HD650)
ANYWAY, don't do it! But if you're curious as I was (and this was years ago when I saw that pic above with red cups)..... then you end up here.
I would imagine this would work on the 660s2 as well!
