Bob A (SD)
- May 11, 2003
Tom,
I read a LOT of online comments and reviews before picking up my Vali 1. Universally folks recommend a nice tube amp over a SS one for the synergy with the HD600. That said there are obviously a great number of excellent solid state amps that would work very well with the HD600 too. I just don't have any recommendations for you.
BTW the Vali 1 (now discontinued) was my first tube amp although I did play with friend's McIntosh and Dynaco back in the day. It's not one that you can "tube roll" for and it does require 30 seconds or so for the subminature tubes to settle down without any microphonics. Other tube amps require a bit (not long at all) to warm up too but frankly I don't see that as a negative in any way.
Oh keep in mind that the Valhalla 2 works well with high impedence cans like the Senns but not so much with cans having much lower ohm ratings. So if you might want to pair it with low impedence cans or IEMs later you'll be disappointed. In that respect the Vali 1 (used) or Vali 2 or Crack/Speedball are better options.
I don't personally see any negatives and only positives with mating the HD600 to a tube amp over a SS one.
