Zankes
- Feb 13, 2012
Can any one recommend me short cable for HD600 which would be an upgrade?
You don't have to break the bank
http://www.head-fi.org/t/793587/hd600-cable-upgrade-newfantasia-1-5-meter#post_12224524
http://www.head-fi.org/t/641565/best-aftermarket-cable-for-the-sennheiser-hd-650/15#post_12216554
http://www.head-fi.org/t/790659/looking-for-good-senn-hd600-cable-maker#post_12284365
http://www.amazon.com/Replacement-Audio-upgrade-Sennheiser-headphone/dp/B00X31OWPC
http://www.ebay.com/itm/Black-Replacement-Cable-Sennheiser-HD420-HD525-HD545-HD565-HD600-headphone-/201318833930
How mobile does it need to be?
You'd have to spend significantly more to do better than the FiiO E12. Read the reviews. It's said to be an excellent amp.
The E12A is for IEMs. The regular E12 is what you'd want for the HD600.
I'll be using them with my laptop btw. Is the E12 very clear but without any additional harshness?
Vali is an excellent choice for the hd600. Extremely resolving. This is definitely a better match for youI can get the Vali for cheaper than the E12, how will the clarity be with the HD 600?
