Shahrose
Yea I definitely recommend the HD650 cable over the HD600 cable. Not the best option, but noticeably better than the 600 cable.
@Ssavage- the E16 combo is nice for the simple fact that it gives you a good DAC that you can simply un-dock and use as a portable amp. i think it's a fantastic piece of work and the price is right too.
if you had a DAC, i'd recommend the Asgard any day of the week. If you can afford to get a better DAC in the future, i'd say stick with the Asgard for now, and enjoy the fruits of upgraditis once you get the new DAC.
Quote:@Ssavage- the E16 combo is nice for the simple fact that it gives you a good DAC that you can simply un-dock and use as a portable amp. i think it's a fantastic piece of work and the price is right too.
so an amp doesnt work w/o a DAC?
An amp will work without a DAC, but what a DAC essentially does is take all the work of converting digital data into audible music away from your computer - in other words, it's an external soundcard.
i thought 600 & 650 have the same cable now....
No sir
The HD600 cable is quite cheap...comparable to something you'd find at your local ratshack. The HD650 cable is more substantial (re: thicker) and is terminated in a 1/4" plug rather than a 1/8" plug of the HD600 cable. I also found the HD650 cable to sound noticeably better, though not as good as expensive aftermarket offerings.
hi, quick question..
Is hd580 and hd600 really identical? If it is so, is there any information or evidence proofing this theory?
