I see you have the JAR800, how do you like it? How much of an improvement is it from an HD800S?
I prefer any HD 800 to any 800S. Unless you favor trading the increased bass perception and the lessened peak for a less open sound, less bass articulation and less overall resolve in the upper treble. The peak can be a problem to some, sure, but fixing it through the HD800S was more of a "blunt device" approach and generally just to increase the price, margins and give the 800 driver a new shelf life.
The same applies to the JAR800 and the JAR800S. No JAR800S will ever sound as open and articulated as any JAR800, it will always be less open and have a lesser ceiling. However it will be a nice departure from the stock 800S and thus is still absolutely worth it.
So:
When you see how much of a departure the JAR800 is from the stock 800 you will never consider stock again.
Bass is even tighter and cleaner now but it will still not extend or rumble below like a HE1000SE. It will dig a bit deeper and cleaner down. That's just how it is and how it will be. Given that music generally lives above 40hz etc or lives in the mids if we wanna be overly philosophical, it's no loss for most genres. The same applies to the HD 600. Ananda and Arya will always batter it in bass, staging/imaging but they will never have its timbre, delicacy, mid tonality, mid to treble transition etc..
This is why the HD 600 is an eternal headphone.
Anyway....
The perception of bass is still increased, there's more punch to it or let's say "concentrated pressure", this is a symptom of less IMD. If you want more volume, go for the 800S but I strongly advise against it. There's no other gain.
Mid and treble are more linear now, the dips have been handled very well. This brings vocals for instance a bit closer but now with the added resolve and cleanliness (thanks to a better waveguide approach) they are absolutely haunting now. Now the stock has already still reference mids but the dips kinda held it back and many people still favored 600/650.
This is gone now. You may call it a Super HD 600 like a few other headphones have been called already (though never really fulfilled that role) but this time it really feels like it. Ironically it had to be another Sennheiser.
Staging and Imaging are a different animal now, this is very important. The HD 800's defuse staging is a mix of FR/dips, reflections, the distance to the driver bla bla bla.
Now if you look at the back fo the driver of stock 800 and the JAR approach you will see that it basically extends out, "guiding" the waves outside of it instead of filtering them out through a pancake. This is one aspect where the staging differs. There is no strong boundary now anymore as naturally the sound isn't "stopped" right at the end of the driver. It's fading out now, not blunted, not cut off. Sure, nobody will ever say his HD 800's stage cuts offs. It's only in the context of a comparison that you will notice it naturally.
Having handled the dips, reflections way beyond stock now, having vocals closer now the stage will appear (as a very broad term) smaller. When I read this at first without owning it, my morale kinda turned to STEADY like a low tier militia in Rome Total War when elephants approach your gates.
Owning the HE1000SE and HEKV2 however I kinda knew what to expect. In the end I prefer the lasersharp imaging of the HE1000SE to the diffuse big staging of the HEKv2 in most cases. As they differ in tonality and timbre none of them replace the other. Strengths and weaknesses as usual.
Back to the stage. It's less diffuse now, quite a bit sharper in placement, the borders are fading out. It gains depth (cues appear/disappear from/into a deeper space) and breathes better. This is the openness I mentioned before. It sounds more open now. Yes, kind hard to believe in the context of the famous HD 800 stage but remember the shortcomings in the HD800's FR which add to the perception.
Treble. Here is where finesse comes into play vs. a blunt approach. Handling the HD800 treble is probably the hardest part of modding.
Let's say you have a big box of blunt needles and some in there are gold while most are of iron, but you only want the gold ones. You dig into it with your hand and try to grab a lot of them in hopes of catching a few golds to select them out.
Imagine doing that with a way lower amount of iron and thus digging out much more gold with each grab. That's how the treble was approached and how it is now.
It's cleaner now, more linear, better extended. More digging out the good stuff. Not polished and detextured, not smoothed over or anything like that.
This is what I call maximizing the HD800's driver potential.
One other important note: The mods are never a fixed template. There's always some wiggle room for your personal preferences. The base will be defined by your personal HD800/HD800S model.
I might have missed a few more aspects but this isn't a review anyway. Maybe I should write one.
