The most amazing thing with the HD600 with the Mixamp pro TR is that I can tell the exact spot where shots are being fired. I can tell is the shots are in the middle of the map, if its in the middle-right hall, whatever. It's really amazing what the Dolby headphone does with the HD600.
And I repeat it, for all that, neither AD700x or DT990 is close to the HD600. Again, I need to put more hours on the DT990, but in the few hours I used I can tell they are not as precise for gaming. I had a real hard time spotting where sounds where coming from, mostly everything felt coming from behind and sounds from the top like UAVs where really hard to locate.
If gaming is the most important aspect then I would suggest auditioning the HD-700, if you think the HD-600 is good at positional audio then the HD-700 takes it to a whole different level and you wouldn't need to double amp since the HD-700 is easier to drive than the HD-600.
