KevinHNgu
- Jul 18, 2014
Whoops, instead of review of both, I meant someone who has them both and would compare/review them for me.
If you find the fit a bit odd with the ATH don't forget to do the hair band mod to the 3D wing support system.
some double-sided window tape...cut to the "right" length to hold the wings together.
in case u are not satisfied with the AT...
u can always send it back n try this out too.
http://www.amazon.com/Yamaha-HPH-MT220-monitor-over-ear-headphones/dp/B00B44N0DA
