Very well written review. A few points I'd like to comment on...
1. In terms of comfort, I too initially had a minor quibble with being able to feel the headband pressing on the top of my head. I found that I had set the sizing too small, and needed to extend the headband by a couple of notches on each side. Once I did that, I still felt the headband on the top, but it wasn't pressing much at all any longer. Much more comfortable then.
2. Regarding build quality, I think it's pretty much average for $150 USD. For its original price of $250 USD or some localities paying even more, I completely agree the build quality is sub-par at those higher prices. I owned the M50x for a while and disagree that the 598 build is worse. It is a bit more flimsy to be sure, but that's by design. It's more flexible, which in turn, makes it more comfortable. The M50x feels more sturdy, solid, and rigid, but I found them far less comfortable. But you are correct, you probably can't sit on them against a hard surface without them breaking.
3. Regarding the sound, I respectfully disagree, to a point, regarding your assessment of the bass. Yes, the 598s have considerable sub-bass roll-off, but how many open back headphones at or near their price range, don't have that problem? Very few open back cans are going to provide potent or even neutral sub-bass. When I first auditioned the 598s, I compared them, side by side, with other open back cans, namely the Q701, HE400S, DT880, and Fidelio X2. Only the X2 had more bass quantity than the 598s, while the others had significantly less bass quantity. You state, "Though roll-off in the sub-bass is common on open headphones, the HD598’s lacking bass extension is comparatively drastic, even taking into account other bass-shy open headphones." I agree with the first part, but not with the last part. Overall, the 598s bass is light to neutral in quantity, but not anemic.
4. Finally, soundstage. I think most users of the 598 will disagree with you that they do not have a wide soundstage, and I happen to be one of them. Of all the open back cans, I've tried, the 598s had a much wider soundstage than most, and only the q701 had a slightly wider soundstage.
So while I respectfully disagree with some of your opinions about the 598s, the review itself was very well done. Thanks for sharing it!
Thanks for the feedback, here's my reply:
1) Maybe it's just my head, when I extend it to 5 clicks the HD598 are secure on my head (not overbearing) but the headband pressure is present. When I extend it to 6 clicks, yes, the headband pressure goes away, but the headphones feel like they'll fall off my head if I so much as look down. I do have a small-ish head size (average for Asian maybe) so that could be why I have that minor issue. And I do mean minor, I don't usually get too hung up over that minor problem.
2) I don't think I said the build was bad, just underwhelming at the price. While it's true that the M50x and HD598 were built for different purposes, small things like the headband and headband arms being metal instead of plastic would've been nice touches, especially given Sennheiser's original MSRP. Also, maybe I should add this in the review, there are definitely other headphones that have more questionable build, but given the HD598's popularity, I thought it was important to point out that a) it isn't the best, and b) owners should probably take good care of it.
3) Perhaps it's the way I phrased my comments on the bass, but this is what I think in a nutshell:
- sub-bass is lacking: this isn't unusual for open headphones, due to bass roll-off. I do not begrudge the HD598 for having lacking sub-bass.
- mid-bass is noticeably absent: this is where I found the HD598's fall-off in the bass to be somewhat jarring. Open cans like the HD518, HD558, K612, and even some Grado/Alessandro headphones I've tried retain some level of mid-bass presence. The HD598's upper bass is very much there, but anything lower just seemed like it jumped ship and refused to show.
TLDR: When I said I wished the HD598 had more "even bass extension", I really meant I wished the bass extended a little lower into the mid-bass, because that would've made it much more enjoyable for more modern music. The severity in the roll-off from upper mid-bass is odd even for an open headphone, in my opinion.
4) Maybe it's how I defined sound stage personally, or maybe I do perceive sound stage differently from people, but I seem to disagree with a lot of people's views on what does and does not have "wide sound stage". For instance, some people said the Sony XBA-H3/Z5/A3 have "wide sound stage" and while iI did think it was much more spacious sounding than almost any other IEM, I didn't think it sounded like a full-sized headphone like some people thought.
Back to the HD598 and why I thought it didn't have a wide sound stage, here's what I define as "wide".
If it extends beyond the cup to provide music in a space that is perceived to be beyond the headphones, that's a wide sound stage. If the space stays "within" the cups, it's narrow or normal.
With my HD598, I never got the feeling that any sound from the left or right extended beyond the cups. Everything was confined within the width of my head. The HD598 does, however, a) sound very tall, and b) have excellent positioning and separation within the space given.
So, within that small space I perceive sound coming out of the HD598, I feel the sense of space, but I don't get the feeling that it's wide or extends beyond the headphones themselves.
I'm not a headphone expert by any means, I've only demoed a good handful, but headphones I'll say have "wide sound stages" would be the Beyerdynamic T90 and the AKG K612. Both of those headphones produced sound beyond the headphone itself, and I felt like sound came further away than it had any right to.
Thanks a lot for your respectful feedback. I really enjoy having discussions like these. It's the reason why I joined this forum.
