KopaneDePooj
By reverse-wearing do you mean left on right and right on left?
Yes, just for testing.
As an owner of both the HD598 and the HD700, here is what I have to say about the two headphones:
The HD598 and the HD700 are similar in that they both have a very open and large soundstage. Both also are most definitely not dark headphones.
Improvements:
- Bass on the HD700 is noticeably better. Hits harder (but not overwhelmingly so), goes deeper, and is more textured on the HD700.
- Soundstage is even better on the HD700. Slightly wider, but noticeably deeper. Imaging is also noticeably better on the HD700, which is quite impressive since the HD598 already does a great job at that. Layering is also much better on the HD700, as it's a lot easier to tell whether things are further or closer to you than on the HD598.
- Notes are more detailed and textured on the HD700.
- While the HD598 is pretty comfortable, in my opinion the HD700 is even more comfortable. The HD700 pretty much disappears from your head shortly after you put it on.
Weaknesses of the HD700:
- Depending on the music you listen to (genre and how well produced it is), the treble on the HD700 can be fatiguing. The HD598 is smooth enough for this to pretty much never happen unless you get an extremely bright amp/DAC or you purposefully mess with EQ, while on the HD700 this isn't the case.
- HD598 is easier to drive, as it sounds good almost out of anything. The HD700 needs better quality gear to truly shine, though it can still sound decent out of something like the FiiO E10K.
Hope that helps!
I agree with those comparisons, that was excellent. I also noticed that my 598 has a lot of distortion when I turn up the volume on my stereo receiver. The driver is apparently not as high fidelity as something like the HD 700.
Plugged into a MacBook or a tablet or phone, no distortion. Just high-powered receivers.
My HD449, HD598 And Beyerdynamic DT990 had this. HD650 and T1 doesnt have this thou.Distortion here too. When amped with FiiO E10k with bass setting on and or with high gain on. Not so on all my other headphones.. Ath M50x, Ath M40fs, Phillips SHP9500, Superlux EVO HD 681, Bose AE2. All amped with FiiO e10k. If I don't apply bass boost and or too much volume it's fine but still bugs me. I am in shock that the hd 598 do this. Wasn't expecting that at all. But other than making sure that my settings are not too strong I really like this headphone. But I am still in utter shock that it would make clipping sound when too loud. Not like I would actually listen at that volume but just did not expect them to distort with comparison to all my other cans that don't.
Hey there,
Could someone recomend a good tube amp for the 598's around 300-350 euros? I was thinking a shiit amp maby the valhala but I dont know if this is a good match. My sourse is the idsd micro.
Every oppinion would be much apreciated.
Cheers
Oh I know! What I am looking for is a little more colorfull and warm sound of a tube amp, just for fun. I only use idsd micro in eco mode. What I am looking for is more fun sound.
Received the SHP9500 after a long delay, courrier messed things up! Will do comparsions soon...
Nice! Then yes, take a look at most popular and broad-used (it's very important) amps like Schiit Valhalla 2, as you have mentioned.
They pairs very well together, good bunch of people noted that in this very thread.
Not only it will drive headphones to their fullest, but it will do great for your future upgrade of headphones.
