Thanks for your detailed response and for sharing so much information.Hi @carsan.
Source : this review of the HD 560S made by a Polish sound engineer (compared to his old Sennheiser HD 600):
https://estradaistudio.pl/testy/sprzet-studyjny/1745-hd-560s-sluchawki-wokoluszne (HD 560S)
This review can be compared to the one of the HD 400 Pro (alas without graphs) written by the same Polish sound engineer:
https://estradaistudio.pl/testy/spr...eiser-hd-400-pro-otwarte-sluchawki-dynamiczne (HD 400 Pro)
On this Polish review of the HD 560S (compared to its old HD 600), the frequency (tonal) balance of the HD 560S between 7 and 14 KHz seems very good, in any case better than that of the HD 600 .
Concerning me, concerning my copies of these headphones (HD 560S and HD 400 Pro), I confirm that my HD 400 Pro is less brilliant in the treble than my HD 560S. It's evident for listening to cymbals and bells.
Objectively speaking, I even measured a level difference of -1.3 dB at the frequency of 5 KHz for my HD 400 Pro (vs my HD 560 S), by taking the frequency of 1 KHz, to equalize in level the headsets (for the position of the measuring microphone, centered on debaffled pads).
To the ear, the sine frequency 5 KHz is more marked than the frequency 1000 Hz, for the two headphones, but slightly less with the HD 400 Pro (my copy) than the HD 560S (my copy).
I do not have the 9 KHz frequency in my test audio CD (30 second listening ranges of sine, 1, 2, 5 and 10 KHz).
Unfortunately, at my age (56 years old), the 10 KHz frequency is heard attenuated with both headphones; I will not say if there is a real difference in level at 10 KHz between these two headphones.
However, to the measurements made with the microphone (Phonic PAA3 - Flat measurements; response time 1 second; debaffled pads, but not at all reflecting the real conditions of human listening with headphones), I noted as raw measurements differences:
HD 560S:
1 KHz: 65 dB SPL
2 KHz: 65.2 dB
5 KHz: 70.4 dB
10 KHz: 66.8 dB
HD 400 Pro:
1 KHz: 65 dB SPL
2 KHz: 64.1 dB
5 KHz: 69.1 dB
10 KHz: 68.2 dB
Measures to be taken with a grain of salt, because very critical to the centering of the microphone (in the debaffled pads): the placement was not strictly identical for the two headsets.
The measurement time of each frequency ranges was 30 seconds each: stable measurements for the SPL levels at each frequency during the 30 seconds of each measurement.
Kind regards and happy new year!
