Sennheiser Amperior Impressions Thread
Dec 18, 2015 at 7:07 PM Post #1,007 of 1,054
Why is that? Are/they that much better than the amps? (I think the amps are great)
yes it scales better with an better amp/dac due to the higher damping factor.
Either way compared to the standard plastic capsules, the capsules of the alu and amp improves the low end significantly at the cost of being less comfortable on the head due to the extra weight.
Dec 21, 2015 at 12:39 AM Post #1,008 of 1,054
The hd25 aluminium already exists and yes it's an improvement over the amperior.
Could you desctibe the improvements?
Thanks!
Feb 22, 2016 at 8:51 PM Post #1,009 of 1,054
Can anyone help me? What's the cheapest screwdriver set I can buy to use to replace the clamp set on the Amperiors?
Feb 23, 2016 at 7:26 AM Post #1,011 of 1,054
  You need a Torx T6 screwdriver.
  I personally have these: http://www.amazon.com/gp/product/B000LQEUJ0
  But shop around Amazon or other hardware store.
Thanks! I found a similar set on B&H along with the coiled HD25 cable.
Aug 30, 2016 at 4:31 AM Post #1,012 of 1,054
Hi,
i was wondering...i want to replace my Amperior's cable.
the stock cable i have has a "built-in" cable-clamp on it with screws to attach the cable to the headphones' frame.
all of the cables i see for sale doesnt have that clamp attached, so how am i suposed to fit them?
i cannot remove the clamp from the stock cable.
Thanks
Aug 30, 2016 at 5:06 AM Post #1,016 of 1,054
Yes.
Alternatively,if you're fine with a dual-entry setup, you can just buy an HD600/650 cable (same connectors, symmetrical cable).
Just rotate the cups so the connectors face down.
No clamp required, but the right side is exposed (I don't think you can buy the cover like the one on the left side).
Aug 30, 2016 at 5:13 AM Post #1,017 of 1,054
i'm sorry i didnt understand what exactly is "exposed" with this setup?
anyway, i don't like symmetrical-cable-down idea, ill get a clamp+cable :))
thanks so much for the quick reply!
i was searching everywhere with no answer...where did i miss? :p
i don't even see the Amperiors being mentioned anywhere,
other than Tyll Hertsens' Innerfidelity where i learned about them :)
thanks a lot :)
