Uncle Erik
Uncle Exotic
- Mar 18, 2006
I don't know anything about headphone amps but I do know that Naim Audio deliberately doesn't include a HO on there amps because they think that buying a headphone amp is necessary if you want to listen to headphones. It might mean that headphone amps really are better for headphones but at the other hand: it might mean that they want to sell their Headline Headphone amp that costs 465 euro (and you got to buy a powersupply with it).
And Naim also likes it when you are forced to buy proprietary cables, power cords, power supplies, and get totally and wholly locked into the Naim universe. Any wonder they think you have to buy yet another box, cord, power supply, et al. if you want to run headphones?
Don't get me wrong, Naim makes some nice gear. But their proprietary bent puts me off.
As for using a receiver, they are just fine most of the time. Usually, voltage dropping resistors are used to lower the output from the speaker amp. Good point about the power consumption, though.
Also, Marantz is good about their headphone outputs. I have their SA8001 which has a discrete headphone amp. I used it a lot in the summer here. When it's still 90 degrees out at midnight, I don't want to run tubes to introduce more heat in the room. I just jack directly into the SACD player, and I think Marantz did a great job with it.
Do not bother with a recable. If bass response is weak, that shows up if you measure frequency response. You can actually see it. Now, with another cable, you get the same weak frequency response showing up in measurements. So how do you add something without adding something? The same weak response will still be there. Even if something, somehow, is changed, the bass will measure as weak.
