No I understand the need for the tubing - just called fused how long it should be.
@csglinux i will take you up on the kind offer - will send you a pm. Thanks
Hey guys, quick question: do you install the dampers cloth side facing the IEMs or away from the IEMs?
Thanks!! I have tried the mod and really like them. Thanks for all the help!I usually have them fabric side closest to the IEM (farthest away from the open end of the nozzle). These things can make a difference, but in this case, because the distances are so small, I'd expect the effect of flipping the fabric/cloth side around would be very small.
You're on the wrong thread. You want the KSE1500 thread. That easily surpasses the Fourte. IMHOI really hope this mod can bring me a little closer to Tia Fourte.
Yes, unfortunately there's no way to avoid a little stack with the KSE1500.I was interested in KSE1500, but don't want to stack. Taking the foam from the end of the blue filter helped some.
