Mmet
- Jan 2, 2014
Hello Friend,
could inform me of shure models, what do you have?
è I have the Shure SE535-CL.
like a feedback.rsrs
In the case of my shure use an IPOD + EQ + Shure SE535,
When increasing the total volume of my iPod, the sound coming out of shure seems half trembling in the acute,
Type the music of slipknot - the sound of dishes me sounds kind of shaky, I wonder if it has the Shure SE535, the sound in a natural way or acute this excelling on the other instruments of music.
so you play with the eq ... you raise the treble ? if yes that would what likely affecting the quality of the treble and then after the eq you raise the volume of the ipod that makes a lot of distortion .. i think that using a quality amp will solve that problem and might decrease the need of boosting the treble ( or playing with the eq from the first place ) to some degree ... you may try that solution first
