Jones Bob
- Mar 22, 2013
Is that similar to playing country music backwards???
Exactly. It's settled science.
Don't engage the invert phase button for extended periods. That could undo the whole burn-in process.
If this is a serious comment you got a lot of backreading to do about what differentiates Yggdrasil from other DACs!
Yggy claims to provide 21 real bits of resolution (see ENOB - effective number of bits). As I understand it there are lots of DAC chips that process at 24 or 32 bits but this doesn't mean they resolve this many bits i.e. provide that degree of musical information.
Nor - for that matter - do our recordings provide anything close to 24 or 32 bits of resolution (though they may in principle have that much dynamic range, but that's not the same thing at all). It's easy to provide 24 or 32 bit music files but this refers to their information-carrying capacity not what they deliver.
This is all as I understand it. There are many here who can explain it better.
Shall we get into the discussion of "at what level of resolution can our ears hear" as well" to add to the MY DAC HAS MORE BITS THAN YOURS argument? I jest and do think you explained it quite well. HOWEVER, if we do assume (for just a brief moment) that we're using all 21 bits of range with purposeful data, isn't it a bit counter productive to squash that signal going into the yggy?
:rolleyes:
Thanks for the great post. This info can save us a lot of grief.
I had a similar experience when I hooked a directional cable the wrong way into Yggy. Three days later Yggy started disassembling itself.
Always make sure the direction arrows on your cables are aligned with electron flow in your system. Otherwise there will be a build up of bass molecules in your source that can lead to an explosion.
Spectacularly occured once at RMAF in 1998. 6 audiophiles were killed. 14 were hospitalized for Brilliant Pebble removal.
Are we talking about interconnects here? This is shocking.
I tried some Shunyata directional fuses in my amp.
Long story short, I inserted them in the wrong way.
Two months down the track, I received a refund from my electricity provider.
Directional fuses for the WIN.............
