earnmyturns
I am about to start using Sonos Connect as a streamer to my Yggy - I understand that the stock Connect is not the greatest sounding source due to high jitter, but that using the Wyred 4 Sound Remedy reclocker makes a world of difference. Has anyone used the Sonos through the Remedy to the Yggy? If so does it make an appreciable improvement? Thanks for any feedback
Matt
Do you really want to do this, it seems a very imbalanced setup with a superior DAC connected to a relatively low-end digital source. Sound Remedy may help, but instead why not look for a better streamer unless you are stuck with Sonos for some reason? I recommend the Sonore microRendu, but even their lower-priced Sonicorbiter SE is likely to do better. All of the Sonore streamers support a bunch of different streaming protocols. Just a very satisfied Sonore user.
