Good morning folks...
Sorry if this might not be the right thread... I've searched around a bit but couldn't find "new" info/threads about them:
I have ONE CENTER speaker (KEF Q600) that I no longer use... but thinking of having a small 2 channel setup in the spare/guest bedroom... something super "simple"... has anyone around used 2 center speakers as they were " regular" left & right speakers?
And the other question: WYRD
My current setup sends the USB signal from the computer to the Bifrost via USB, and every now and then there is a "whinning" sound added to the "regular" sound, as if it's getting some added distortion from the tubes... I replaced the tubes as I initially thought they were getting bad... but then I found out that if I simply unhook the USB cable for a second or two... it clears out (and also, that it won't occur if I use optical able it is not a biggie because it doesn't happen ALL the time but would it be something WYRD would fix?
Thanks a bunch!
Cheers!
I have a pair of Wharfedale 10.1 center speakers that I got at a substantial discount. The 10.1 bookshelf speakers have one six inch woofer. The center channels have two. Both speakers have the same frequency response.
The centers work great as bookshelves, stood on end.
They are a bit brighter than my LS 50s, which is a good thing as at my age I need all the help I can get.
