Schiit SYS Passive Preamp
Jun 14, 2015 at 3:34 PM Post #106 of 231
Nope, that is definitely one of the intended purposes
As long as you don't lose digital information, you're set!
Jun 23, 2015 at 1:05 AM Post #107 of 231
Just to chime in, I found the Sys reasonably priced. I use mine with a Schiit Lyr2 headphone amp. One input is for a Bifrost Uber. The other side is for a line input cable to run my Pono Player direct to the amp. I found no change in sound adding the Sys to my small system.
Jun 23, 2015 at 12:08 PM Post #108 of 231
I found the Sys to be a great complement for my vinyl and digital rigs.
I have the following setup:
iPod classic 160 gig -> Pure i20 -> Bifrost -> Sys -> Lyr 1
Thorens TD 125 mkII -> Mani -> Sys -> Lyr 1
The sys makes a great way to flip between sources and is nice to A->B listen between loss-less digital and vinyl sources.
Jul 18, 2015 at 8:09 PM Post #111 of 231
Just wondering if anyone has any experience with thisthis http://www.smproaudio.com/index.php/en/products/monitor-controllers/m-patch-2
Seems like it might fill the gap of multiple in, multiple out
Sep 1, 2015 at 8:28 PM Post #112 of 231
I ran into the Schiit SYS trying to solve the opposite problem -- 1 output (integrated digital DAC/AMP) to 2 output devices (speakers, a highly colored tube amp that I only very occasionally use).  Schiit in their FAQ states . . .
Hey, can you use this in reverse to switch 1 input to two outputs?
Yes, with the volume all the way up. But why not just use RCA Y-cables or splitters, like these?
The link is to a $0.56 Y-spliiter on monoprice.  So the question is . . . is there actually a reason not to use a Y splitter?
Sep 1, 2015 at 9:24 PM Post #113 of 231
Some people say the Y-splitter is inaudible. Others disagree. My recommendation is is to try the splitter first, because it is cheap. If it doesn't work, you always have the Sys as a backup purchase option
I would only recommend you try the Sys first only if there is a time constraint, such that you cannot try the Y-splitter first, ordering the Sys later if the first option fails.
Sep 2, 2015 at 3:17 PM Post #114 of 231
I used a Y splitter so my Lyr2 could be attached to both a bi frost dac or a Pono Player. It turned out, I had to have the bi frost on even to listen to the Pono. Without the bi frost on the Lyr2 gave like 1/4 power. Since it it a Y, both sources are always active. The Sys solved the problem as only one,source is available at a time.
Sep 10, 2015 at 2:06 PM Post #115 of 231
Hey guys, dumb question for you about this SYS passive preamp from a noob. I just ordered a Maverick Audio D1 Tubemagic Plus. I mostly bought it for use with active monitors (Airmotiv 5s) since I don't expect much headphone time until late at night.
However, the headphone does not mute the speakers. So, I am thinking of using a second power strip to just plug in my speakers...but could I just hook up this SYS to control the volume to my speakers? For example D1 DAC output -> SYS input/SYS output -> active monitors? I'm assuming if it works I shouldn't get any noticeable loss of quality.
Edit: I'm also looking at something like the Emotiva control freak.
Sep 10, 2015 at 2:13 PM Post #116 of 231
Definitely! That's what the SYS is for. Just connect your DAC to RCA input 1 and out to your powered monitors. Keeping the SYS on a single channel is not a problem. If you later decide to use it to switch between speakers and say a headphone amplifier, you're good to go. Oh, and the only dumb question is the one that isn't asked
Sep 10, 2015 at 2:46 PM Post #117 of 231
Good to know, thanks! I'm still debating the SYS or Control Freak but I have a feeling I'm going to buy lots of Schiit in the future. :D
Sep 10, 2015 at 3:01 PM Post #118 of 231
Yeah - having other Schiit would make for a nice look. Unfortunately my Schiit is the off-color "black" style. But if you have a stack of same color Schiit, it certainly looks good!
The reason I like the Sys is I will sometimes use it in reverse. Such as at a recent headphone meet, I plugged in two DAC and used the output for the input. You can do this as long as you set the volume to max. But, I like to do odd things like that. Having the two inputs helps me cope
Sep 13, 2015 at 11:39 AM Post #120 of 231
